SAVANT POLARIS SPORTSMAN REAR FLAT BASKET
SKU: RCK561
Price: $149.95
Description
Carry more gear with confidence and less hassle! Designed to hold more cargo than competitive baskets while keeping empty weight to a minimum, these baskets are designed to mount directly onto the original factory tubular racks so no cutting or drilling is necessary for installation. If you carry a lot of riding/hunting gear and like easier access without undoing many bungee straps from your stock rack, this basket is for you. Their open and rounded handrails add to available space and load stability. Also, these curved rails help prevent hang-ups on low hanging limbs, etc. Savant Rear ATV Wire Mesh Basket Racks are made from 3/4” square tubing (10lbs lighter than the 1"), 16-gauge expanded metal, solid welded at every joint for strength, and have a gleaming powder-coat finish. APPLICATIONS POLARIS SPORTSMAN 400 2005 POLARIS SPORTSMAN 450 4X4 2006-2007 POLARIS SPORTSMAN 500 4X4 2006-2008 POLARIS SPORTSMAN 500 HO 4X4 2005 POLARIS SPORTSMAN 600 2005 POLARIS SPORTSMAN 700 2005-2007 POLARIS SPORTSMAN 800 2005-2008
