WHEEL SPACER 1" 4/110 (One Pair)
SKU: WT4/110-1
Price: $66.95
Description
Spacer Width: 1"
Applications:
1" Honda/Yamaha/Kawasaki spacers 4/110 (1 pair) fits most Honda and Yamaha utility ATVs and also fits the Kawasaki 650i/750i IRS Brute Force. Also fits Bennche models.
