WHEEL SPACER 1"4/156 (One Pair)
SKU: WT4/156-1
Price: $88.95
Description
Spacer Width: 1"
Applications: Most Polaris utility ATVs and Side by Side models. Does not fit 2009-2011 550/850 Sportsman XP. (SEE WT4/156-1S OR WT4/156-15S FOR 2009-2011 POL.550/850 SPORTSMAN XP)
