WHEEL SPACER 1.5" 4/156 (One Pair)
SKU: WT4/156-15
Price: $102.95
Description
Spacer Width 1.5"
Applications:
 Most Polaris utility ATVs and Side by Side models. Does not fit 2009-2011 550/850 Sportsman XP. See WT4/156-1S or WT4/156-15S for 2009-2011 Polaris 550/850 Sportsman XP)
