Spacer Width: 1.5" Polaris (Sport) spacers 4/156 (1 pair) (1.25 pitch stud)
Applications:
2009-2010 Polaris 550/850 Sportsman XP and most sport ATVs with a 4/156 bolt pattern and 10mm x 1.25 thread pitch wheel studs and lug nuts.
