1" POLARIS (SPORT) SPACERS 4/156 (One Pair)
SKU: WT4/156-1S
Price: $88.95
Description
SPACER WIDTH: 1" Polaris (Sport) Spacers 4/156 (1 pair) (10mm x 1.25 pitch stud)
APPLICATIONS:
2009-2010 model Polaris 550/850 Sportsman XP and most sport ATV's with a 4/156 bolt pattern and 10MMx1.25 thread pitch wheel studs and lug nuts.
