WARN RT25 2500
WARN RT25 2500
WARN RT25 2500" Winch
SKU: WARN-75000
Price: $344.95
The Best Selling ATV Winch for Work or Play!
The RT25 is a versatile, durable winch with a just-right 2,500 lb. pulling capacity and 50' of durable wire rope - making it perfect fit for Utility ATVs 350cc and up. This industry-standard winch has an all-metal 3-stage planetary geartrain; full sealing to keep the elements out; a patented disc brake for excellent control; a short-throw clutch; and an efficient electrical system for less battery drain. A handlebar-mounted mini-rocker switch provides simple, effective control.
RT25 SPECS/PART NUMBERS
Capacity: 2500 lbs. (1134 kgs)
No-load Linespeed: 18 ft./min. (5.5m/min)
Full-load Linespeed: 5 ft./min. (1.5 m/min)
Motor*12V DC, .9 hp (.7 kW) permanent magnet, Sealed
Control: Sealed handlebar-mounted mini-rocker control switch
Geartrain: All-metal 3-stage planetary
Gear Ratio: 154:1
Clutch (freespooling): Sliding pin and ring gear
Brake: patented disc brake
Rope: 50' Aircraft-grade Wire 3/16" diameter (15m, 5mm diam.)
Drum Diameter/Length: 2.0"/2.9" (52mm / 74mm)
Fairlead: Roller
Recommended Battery*12 Amp/hour minimum
Battery Leads: 8 gauge
Duty Cycle: Intermittent
Warranty: Limited Lifetime (valid in USA and Canada only)
Winch Weight: 15.6 lbs. (7.1 kgs)
*Designed for use with 12V DC battery systems only. No other voltage systems recommended:
PERFORMANCE DATA PULL BY LAYER
Line Pull
Lbs.(Kgs.)
Line Speed
FT./min(M/min.)
Motor
Current
Pull by layer
layer/Lbs(Kgs.)
0 18 (5.5) 14 1/2500 (1134)
500 (227) 16 (4.9) 39 2/2150 (975)
1500 (680) 10 (3.0) 96 3/1845 (836)
2500 (1134) 5 (1.5) 157 4/1586 (719)
