With 3,000 lbs. of pulling power and 50' of durable wire rope, the RT30 is a powerhouse ATV winch. Get-it-done features include an all-metal 3-stage planetary geartrain; full sealing to help keep the elements out; and a patented disc brake for optimum braking performance. With a corded remote, a handlebar-mounted mini-rocker switch and a short-throw clutch, the RT30 provides a great combination of power and control.
| RT30 SPECS/PART NUMBERS |
| Part Number: 81654 (24V) |
| Rated Line Pull: 3000 lbs (1360 kgs) |
| Motor*: 12V DC, .9 hp (.7 kW) permanent magnet, Sealed |
| Controls: Corded remote and handlebar-mounted mini-rocker control switch |
| Geartrain: All-metal 3-stage planetary |
| Gear Ratio: 154:1 |
| Clutch (freespooling): Sliding pin and ring gear |
| Brake: patented disc brake |
| Drum Diameter/Length: 2.0"/2.9" (52mm / 74mm) |
| Fairlead: Roller |
| Rope: 50' Aircraft-grade Wire, 3/16" diameter (15 m, 5mm diam.) |
| Recommended Battery*: 12 Amp/hour minimum |
| Battery Leads: 6 gauge |
| Duty Cyle: Intermittent |
| Warranty: Limited Lifetime (valid in USA and Canada only) |
| Winch Weight: 15.6 lbs. (7.1 kgs) |
| *Designed for use with 12V DC battery systems only. No other voltage systems recommended: |
| PERFORMANCE DATA |
PULL BY LAYER |
Line Pull
Lbs.(Kgs.) |
Line Speed
FT./min(M/min.) |
Motor
Current |
Pull by layer
layer/Lbs(Kgs.) |
| 0 |
18 (5.5) |
14 |
1/3000 (1360) |
| 1000 (455) |
13 (4.0) |
67 |
2/2580 (1170) |
| 2000 (907) |
8 (2.4) |
125 |
3/2220 (1007) |
| 3000 (1360) |
4 (1.2) |
198 |
4/1910 (866) |
