WARN RT40 4000# Winch
SKU: WARN-77000
Price: $537.95
A Winching Workhorse for Side X Sides!
Riders looking for on-the-job performance and outstanding durability will want the RT40 for their Side X Side. The winch showcases 4,000 lbs. of pulling muscle and 55' of durable wire rope - the longest in the WARN Powersports lineup. This winch has tons of standard features including a patented disc brake for great control; a fully sealed drivetrain; a reliable and smooth all-metal 3-stage planetary geartrain; short-throw clutch; a corded remote and mini-rocker control switch for winch operation; and an efficient electrical system for long pulls and less battery drain.
RT40 SPECS/PART NUMBERS
Rated Line Pull: 4000 lbs. (1814 kgs)
Motor*12V DC, 1.5hp (1.1 kW) permanent magnet
Controls: Corded remote and mini-rocker control with universal mounting bracket
Geartrain: Sealed, all-metal 3-stage planetary
Gear Ratio: 136:1
Clutch (freespooling): Sliding pin and ring gear
Brake: patented disc brake
Drum Diameter/Length: 2.0"/4.7" (52mm/119mm)
Fairlead: Roller
Rope: 55' Aircraft-grade Wire, 7/32" diameter (16.8m, 5.5 mm diam.)
Recommended Battery*14 amp/hour minimum
Battery Leads: 6 gauge
Duty Cyle: Intermittent
Warranty: Limited Lifetime (valid in USA and Canada only)
Winch Weight: 14.4 lbs. (6.5 kgs)
*Designed for use with 12V DC battery systems only. No other voltage systems recommended:
PERFORMANCE DATA PULL BY LAYER
Line Pull
Lbs.(Kgs.)
Line Speed
FT./min(M/min.)
Motor
Current
Pull by layer
layer/Lbs(Kgs.)
0 25 (7.6) 31 1/4000 (1814)
1000 (455) 16 (4.9) 106 2/3440 (1560)
2000 (907) 11 (3.3) 175 3/2958 (1342)
3000 (1360) 7 (2.1) 245 4/2544 (1154)
4000 (1814) 4 (1.2) 308
