AQUA HOT RUV HEATER- HYDRONIC (WATER BASED) HEATER
SKU: HEATER-AH-2Price: $219.95
NOTE: Universal Installation Kit is Required...See part# HEATER-AH-IK
Aqua-Hot lightweight hydronic (water based) heating systems plumb into your OEM coolant lines and provide an affordable, quiet, reliable, comfortable and adjustable heat source to any side x side...WHY SUFFER?
Perfect for any off road situation, Aqua-Hot Off Road Heaters are designed with your needs in mind.
The adjustable mounting system and integrated, variable-speed switch make installation a breeze. Low amperage fans draw as little as 2 amps.
Made of tough, high-strength nylon 6/6, the housing resists harsh elements and challenging environments. And, at only three and a half pounds and 5.5" x 5.5" x 9.5" Aqua-Hot Off Road Heaters delivers big heat from a small, lightweight package.
Aqua-Hot 200 - While still very efficient in electrical usage, this model draws up to 2 amps with fan output from 0 to 200CFM.
Product Features
* Compact Size - Allows mounting in tight areas
* Low 2 amp draw
* Universal Mounting System - Bracket rotates 180° top to bottom, mounts to floor, firewall or under dash
* Slotted Mounting Arm - Space-adjustable mounting for tight fit * Serrated Locking Clamp - Positive locking at any bracket angle * Nylon 6/6 Housing - tough, durable, high-strength material for use in all environments
* Radial Axial Fan - Quiet heating, no need to turn up the radio
* Integrated Switch - No wiring or mounting needed
* Variable Speed - Set the fan speed to your comfort level
Product Specifications
Aqua-Hot 200 (HEATER-AH-2)
Size: 9.5"(w) x 5.5"(d) x 5.5" (h)
Weight: 3.5 lbs
Hose Barb OD: 3/4"
Switch: Integrated, Variable Speed
Fan(s): One 12V DC Radial Axial Fan
Fan CFM: Variable, 0 to 200
Volts: 12
Watts: 24
Amps: 2 amp
Mounting: Mounting bracket rotates 180° from top to bottom with slotted arm and serrated clamp.
