AQUA HOT RUV HEATER- HYDRONIC (WATER BASED) HEATER
SKU: HEATER-AH-1
Price: $189.95
Universal Installation Kit is Required...See part# HEATER-AH-IK
NOTE: Universal Installation Kit is Required...See part# HEATER-AH-IK
Aqua-Hot lightweight hydronic (water based) heating systems plumb into your OEM coolant lines and provide an affordable, quiet, reliable, comfortable and adjustable heat source to any side x side...WHY SUFFER?
Perfect for any off road situation, Aqua-Hot Off Road Heaters are designed with your needs in mind.
The adjustable mounting system and integrated, variable-speed switch make installation a breeze.  Low amperage fans draw as little as .5 amps (yes, less than 1/2 of an amp!) ensuring long hours of warmth without killing your battery.
Made of tough, high-strength nylon 6/6, the housing resists harsh elements and challenging environments.  And, at only three and a half pounds and 5.5" x 5.5" x 9.5" Aqua-Hot Off Road Heaters delivers big heat from a small, lightweight package.
Aqua-Hot 100 - Draws up to .5 amps (Yes, only 1/2 of an amp) and fan output from 0 to 100 CFM.  When battery power is limited or cabin space is small, this is the heater for you.
Product Features
*Compact Size - Allows mounting in tight areas
*As low as 1/2 of an AMP - Long hours of heat without draining your  battery
*Universal Mounting System - Bracket rotates 180° top to bottom,   mounts to floor, firewall or under dash
*Slotted Mounting Arm - Space-adjustable mounting for tight fit    *Serrated Locking Clamp - Positive locking at any bracket angle    *Nylon 6/6 Housing - tough, durable, high-strength material for use in  all environments
*Radial Axial Fan - Quiet heating, no need to turn up the radio    *Integrated Switch - No wiring or mounting needed
 Variable Speed - Set the fan speed to your comfort level
*Product Specifications
Aqua-Hot 100 (HEATER-AH-1)
Size:     9.5"(w) x 5.5"(d) x 5.5" (h)
Weight:    3.5 lbs    3.5 lbs
Hose Barb OD:     3/4"    3/4"
Switch:     Integrated, Variable Speed
Fan(s):     One 12V DC Radial Axial Fan
Fan CFM:     Variable, 0 to 100
Volts:     12
Watts:     6
Amps:    0.5 (1/2 amp)
Mounting: Mounting bracket rotates 180° from top to bottom with slotted arm and serrated clamp.
