1000 Lumen LED Square Work Light (10-50 Volt) Trapezoid Pattern
SKU: LED-10SQ-TPrice: $108.95
Announcing the 4 inch Square 1000 Lumen LED Work Light that is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications. Waterproof o-ring sealed design with a rugged die cast aluminum housing protects from dust, vibration and moisture in the toughest work environments. LED Work Lights carry a 3 Year No Hassle Warranty.
Trapezoid - Pattern offers a wider yet shorter flood of light than the Spot Pattern. Choose this pattern when you need distance as well as width for illuminating your work area.
Benefits & Features:
- 1000 Lumen 4 inch Square LED Work Light that is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications.
- Long-lasting life of 30,000+ hours - no more broken bulbs and long lasting, reliable light output to illuminate your work areas and equipment.
- Mounting Bracket can be tilted forward or back 180 degrees to angle the light where you need it.
- Waterproof o-ring sealed design with a rugged die cast metal housing protects the LEDs from dust, vibration and moisture.
- Featuring exclusive premium optics that boost the LED power.
- Made with 6 super bright Gen3 White LEDs for an umcompromising flood of light for your work areas.
- The operator of the snowplow pictured at left told us there’s no reflection from the snow like halogen lights & everyone sees it coming & gets out of the way! - a distinct advantage in snowy climates for clearing sidewalks or even plowing parking lots.
- Color temperature: 5700K.
- 10 - 50 Vdc for worldwide use.
- 3 Year No Hassle Warranty.
