500 Lumen LED Round Work Light (10-50 Volt) Spot Light Pattern
SKU: LED-5RO-SPrice: $69.95
Announcing the 4 inch Round 500 Lumen LED Work Light that is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications. Waterproof o-ring sealed design with a rugged die cast aluminum housing protects from dust, vibration and moisture in the toughest work environments. LED Work Lights carry a 3 Year No Hassle Warranty.
Spot - This pattern casts a focused and concentrated long range beam of light for illuminating work spaces or objects in the distance.
Benefits & Features:
- 4 inch Round 500 Lumen LED Work Light is built for the most demanding work environments including material handling, construction, agricultural, forestry, mining and other off road equipment applications.
- A reputation you can count on for quality products - SoundOff is a leading manufacturer of LED safety lighting for law enforcement, bus & truck markets.
- Rated to last 30,000+ hours - no more broken or burned out bulbs. LED lighting provides years of reliable, low maintainance bright output to illuminate your work areas & equipment.
- Mounting bracket is made from a stainless steel and can be tilted forward or back 180 degrees to angle the light where you need it.
- Waterproof o-ring sealed design with a rugged die cast aluminum housing protects the LEDs from dust, vibration and moisture in the toughest work environments.
- Color temperature: 5700K.
- 10 - 50 Vdc for worldwide use.
- 3 Year No Hassle Warranty.
