Mighty Night Light (10-30 Volt) Standard Spot Pattern
Show Picture 1Show Picture 2Show Picture 3Show Picture 4Show Picture 5Show Picture 6
SKU: LED-MNL
Price: $105.95
Amplify your ride's lighting and hit the trails with the Mighty Night Light - the smallest, high powered LED white light available for commercial & public safety use.
The Mighty Night Light is the smallest, high powered LED white light available for commercial & public safety use. Use it anywhere you have restricted space requiring high output. Light is made with our LED Alley light module. It is made with an ultra powerful, multi-chip LED cluster for bright, pure white output. Light has a 3 Year No Hassle Warranty.
Benefits & Features:
 - Introducing the Mighty Night Light, a white LED high powered spotlight for commercial vehicle & public safety use. Compact size allows you to use it anywhere you have restricted space that needs bright, white output.
 - Built with powerful LED Alley light module. Module is encased in a sleek, black surface mount housing.
 - Standard forward lens directs the light in a long, narrow output for spotlight applications.
 - Light can be positioned in vertical or horizontal mounts depending on your needs.
 - Hundreds of uses including the first ever Push Bumper Alley Light or mount to the prisoner partition on undercover vehicles. Flood lens can be used for stepwell/curb/entry lighting on buses for loading & unloading passengers.
 - Light is made with a high density, ultra powerful, 4 diode multi-chip LED with Gen3 LED technology.
 - Die cast aluminum housing with durable Lexan polycarbonate lens. Housing is powder coated with a UV inhibitor to prevent fading.
 - Light has an attached Molex Connector, Mounting Gasket & Hardware with approx. 35 inches of shielded cable.
 - 3 Year No Hassle Warranty.
