EMP Roof for 2011 Can-Am Commander 800/1000
SKU: EMP-ROOF-CMRPrice: $424.95
Ride the trails and get out of the sun with EMP's Roof for 2011 Can-Am Commander 800/1000!
Don't let the intense heat of the sun or drenching rain ruin your ride! The EMP Roof for the 2011 Can-Am Commander 800/1000 will keep you cool and dry in any terrain.
Fabricated from .100" thick 5052 aircraft grade aluminum insures a rigid structure and no rattling. Each roof is laser cut and CNC formed for a perfect fit. The sides are hemmed to add strength, style and a soft edge. The front and rear features a rain gutter so that the water will run off on the sides and not in the middle. Welds are tig welded and ground smooth. The roof is powder coated with a texture black finish to match the stock cage. Shipped in two sections and bolts together along a gasketed water tight seam.
Laser Cut and CNC formed to insure a perfect fit.
Rubber Coated Mounting Hardware.
Water Proof LED Dome Light runs on 100 hours in "AAA" batteries (Included).
Fabricated from almost 1/8" Thick 5052 Aircraft Grade Aluminum.
Powder Coated Texture Black for superior protection (Raw aluminum is available, special order only).
Front and Rear rain gutters.
Bolts together design allows for UPS ground shipping to your door.
Made in USA
