Pro Series Tie Rod/Rack End Upgrade Kit for Polaris Ranger 500/700/800
Show Picture 1Show Picture 2
SKU: PSTRKHD-RNG-1
Price: $64.95
Broken tie rod on your rack and pinion setup? Don't spend hundreds replacing the entire setup! The High Lifter Pro Series Tie Rod for Rack and Pinion setups is an OEM upgrade at budget-friendly prices.
This kit is sold as a single tie rod/rack end kit. It is designed to replace the left or right side tie rod/rack end. Only one tie rod set up is included in the kit, so you will need to order a quantity of 2 kits if you want to repace both the left and right sides.
High Lifter's Pro Series Tie Rod Replacment Kit for rack and pinion setups in UTVs. This OEM upgrade replaces a single tie rod/rack end and is crafted from heavy-duty steel that can withstand harsh conditions.
The kit features:
  - Heavy-duty heim joint
   - Hex adjustment bar
- Custom alignment cones
   - Heavy-duty hardware
   - Detailed instructions with photos
One kit will replace the left or right side. If you want to replace both the left and right sides, a quantity of two (2) kits will need to be ordered.
Polaris Ranger 500 (2009-2010) New body style with dual A-Arms and shocks only. (Does not fit 500 Ranger with single lower A-Arms and struts.)
Polaris Ranger 700 (2009) Standard cab with dual A-Arms and shocks only. (Does not fit 2009 700 Ranger Crew with single lower A-Arms and struts.)
Polaris Ranger 700 HD (2009) (Standard Cab)
Polaris Ranger 800 (2010-2012)
Polaris Ranger 800 Crew (2011-2012)
Polaris Ranger 800 6x6 (2011-2012)
Polaris Ranger 900 DSL (2012)
Polaris Ranger 900 DSL Crew (2012)
Notes:
High Lifter's Pro Series Alignment Kit (PSAK-1) is REQUIRED if you plan to install ANY brand of Ranger lift kit and have updgraded or are upgrading to the Pro Series Ranger Tie Rod/Rack End Kit. This kit reduces tie rod angles and also upgrades from the OEM 10mm bolt to a 1/2" Gr. 8 bolt to match the heavy duty heim joint in our Tie Rod/Rack End Kit. The alignment kit comes with 2 alignment cones and all hardwared required to upgrade both sides of the Ranger.
A MINIMUM of a 1" wheel spacer is required on the front if you are running 12" diameter factory or aftermarket wheels for the wheel to clear the tie rod with the alignment cones installed. If you are running wide tires, a 1.5" or wider spacer may be required depending on the width of the tire for tire to shock clearance at full lock steering.
