High Lifter Signature Series Lift Kit for Polaris Sportsman 450/500/600/700/800 (See Applications)
SKU: PLK800-50Price: $159.95
Bigger. Badder. And now even more BOLDER. Take your ATV to the edge with High Lifter’s 2” Signature Series Lift Kit. Increase your ground clearance and make room for larger tires to dig deep and ride hard in most any terrain. Our engineers and staff have spent over 15 years perfecting the ultimate ATV lift kit. The product? The Signature Series Lift Kit is even easier to install with a bolt-on application that consistently measures truer over competitor products.
The High Lifter 2” Signature Series Lift Kit relocates the shock mounts to provide additional lift making room for larger tires and tightens suspension. Each Lift Kit part is precision cut and zinc plated for durability and reliability in any environment.
This kit contains a set of front spring spacers!
2” Signature Series Lift Kit Features:
· High Lifter logo precision laser cut into each kit
· User-friendly instructions
· Zinc plated for durability
· Front and rear lift
NOTE: Be sure to always check CV boot clearance at strut housing during installation as you may have to grind the aluminum strut housing to create sufficient clearance for CV boots (even if you're running stock CV axles).
This kit does not fit the Polaris X2 models.
FITS:
Polaris Sportsman 450 (06-08)
Polaris Sportsman 500 (2005; built after 1/1/2005 only!)
Polaris Sportsman 500 (06-10)
Polaris Sportsman 500 (11-12) - Rear Axle bar kit (ABK-P-2), Rear Pro Series Axles or Rear Gorilla Axles are REQUIRED on 2011-2012 models!
Polaris Sportsman 600 (2005; built after 1/1/2005 only!)
Polaris Sportsman 700 2005 (2005; built after 1/1/2005 only!)
Polaris Sportsman 700 (06-07)
Polaris Sportsman 800 2005 (2005; built after 1/1/2005 only!)
Polaris Sportsman 800 EFI (06-10)
Polaris Sportsman 800 2011-2012 - Rear Axle bar kit (ABK-P-2), Rear Pro Series Axles or Rear Gorilla Axles are REQUIRED on 2011-2012 models!
