RHINO (ORIGINAL) ROOF POLYETHYLENE (BLACK)
THIS IS THE ORIGINAL ROOF DESIGN FROM 2005.
FITS: YAMAHA 660 RHINO!!!!!
Details:
This roof is perfect for keeping direct sunlight off of you as you hit the trails in your Rhino. It also makes the ride a lot dryer in the rain.
Double Wall Roto-Molded Construction
Injected with foam insulation to stiffen the roof up
Foam acts as a insulator to cut down on heat transferance
Most durable Rhino roof on the market hands down
Will not warp
Roof is contoured toward the middle
Plastic has UV Inhibitors to resist fading
Easy installation
Includes brackets and hardware
No holes to drill
Don't buy a flimsy roof from the factory at a higher cost, buy the best. Remember if you buy the best you will always be satisfied!!
