SKU: PSTS-32
Price: $16.95
Protect your tires with the industry-leading tire sealant!
  • Seals punctures up to 1/2" in the tread.
  • Seals punctures up to 1/4" in the sidewall.
Fill 'er Up!
32 oz. per tire recommended.
  • Will not freeze or harden.
  • Will not rust steel or corrode aluminum.
  • Will not dry rot in stored ATVs.
  • Will not clog valve stems.
  • Biodegradable and water-soluable.
Proudly made in the USA!
