INSTALLATION PUMP FOR PRO SERIES TIRE SEALANT 5 GALLON PAILS
SKU: PSTS-IPPrice: $104.95
Distrubuting tire sealant is a breeze with our custom refill pump for our 5 gallon pail of High Lifter's Pro Series Tire Sealant.
About High Lifter's Pro Series Tire Sealant
Fill 'er Up!
32 oz. per tire recommended.
- Will not freeze or harden.
- Will not rust steel or corrode aluminum.
- Will not dry rot in stored ATVs.
- Will not clog valve stems.
- Biodegradable and water-soluable.
Proudly made in the USA!
