HLP PRO SERIES TIRE SEALANT - 5 GALLON PAIL
SKU: PSTS-PL
Price: $272.00
Lots of tires to protect? Our 5 gallon bucket is your budget-friendly solution to locking in air and locking out leaks!
Fill 'er Up!
32 oz. per tire recommended.
  • Will not freeze or harden.
  • Will not rust steel or corrode aluminum.
  • Will not dry rot in stored ATVs.
  • Will not clog valve stems.
  • Biodegradable and water-soluable.
Proudly made in the USA!
