High Lifter Pro Series Arched Radius Bar for Polaris RZR 900 XP, RZR 900 XP
High Lifter Pro Series Arched Radius Bar for Polaris RZR 900 XP, RZR 900 XP "4" Seater
SKU: PSRA-RZR9
Price: $199.95
A bent rear radius bar on your RZR 900 XP will hinder your ground clearance and can quickly lead to getting stuck because you’re hung in a rut or on a rock or a shortened ride. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Arched Radius Bar.
Want to upgrade your upper and lower radius bars? Check out the Arched Radius Bar's companion with the Pro Series Upper Straight Radius Bar (PSRA-RZR9-1).
A bent rear radius bar on your RZR 900 XP will hinder your ground clearance and can quickly lead to a broken ride or getting stuck because you’re hung in a rut or on a rock. High Lifter maximized the available space in the rear radius bar area with extreme curvatures to give you the most ground clearance AND still protect your axle with the Arched Radius Bar.
Made from 1 ¼” x 3/16” DOM steel tubing, the Arched Radius Bar is a beefy addition compared to the OEM bars (3/4”) and other competitors (1”). The simple bolt-on kit also features a 5/8” heim joint with a load rated at 17,955 pounds and polyurethane bushings for rugged durability in the deepest ruts and along the rockiest terrain.
When comparing the High Lifter Arched Radius Bar to the competitors, you’ll notice that ours give the MOST ground clearance across the entire bar and the most strength. Something you won’t find anywhere else. You didn’t spend $15,000 on the BEST UTV on the market to save a few bucks on a weak link! High Lifter’s Arched Radius Bar will give you the strength and clearance needed for peace of mind when riding the trails!
The Arched Radius Bars also have an upper companion with the Pro Series Upper Straight Radius Bars. Check them out here (PSRA-RZR9-1).
Product features:
-          Extreme arches for maximum ground clearance.
-          1 ¼” x 3/16” DOM steel tubing
-          5/8” heim joint with a load rating of 17,955 pounds
-          Polyurethane bushings
-          Simple bolt-on kit
-          Instructions complete with photos for a quick install
Polaris RZR 900 XP two seater, standard cab (11-12)
Polaris RZR 900 XP "4" four seater (2012)
