Pro Series Steering Alignment Kit - Ranger 700/800 (09-12)
SKU: PSAK-1Price: $27.95
The Pro Series Steering Alignment Kit includes 2 alignment cones and all of the hardware required to upgrade both sides of your Polaris Ranger.
When you need the Pro Series Steering Alignment Kit:
A. If you own or are buying our 3" Signature Series Lift Kit for the Polaris Ranger (09-12 - PLK800R-50) or ANY brand of Ranger 2”-3” lift kit and have upgraded or are upgrading to our Pro Series Ranger Tie Rod/Rack End Kit. This kit reduces tie rod angles and also upgrades from the OEM 10mm bolt to a 1/2" bolt to match the heavy duty heim joint included in our tie rod/rack end kit.
B. If you own or are buying our Pro Series Forward A-Arm Kit for the Polaris Ranger (09-12 - PSFAA-PR-1) or are upgrading to our Pro Series Ranger Tie Rod/Rack End Kit. This kit reduces tie rod angles and also upgrades from the OEM 10mm bolt to a 1/2" bolt to match the heavy duty heim joint included in our tie rod/rack end upgrade kit.
