WARN XT40 4,000 lbs. Winch with Synthetic Rope and Wireless Remote
SKU: WARN-77500
Price: $689.95
The WARN XT40 Winch - the most EXTREME side by side winch on the market!
If you've got a Side X Side and are looking to outfit it with the most extreme Side X Side winch on the market, look no further than the XT40. It's got 50' of light-weight, easy-to-handle synthetic rope; a wireless control system with a 50' range, plus a mini-rocker control switch; and a sealed drivetrain to keep the elements out and the winch working properly. Other features include an all-metal 3-stage planetary geartrain for smooth, reliable operation; a patented disc brake for outstanding control; a short-throw clutch; and an efficient motor for longer pulls with less battery drain.
XT40 SPECS/PART NUMBERS
Part Number: 77500
Rated Line Pull: 4000 lbs (1814 kgs)
Motor*12V DC, 1.5 hp (1.1 kW) Permanent Magnet
Controls: Wireless Remote and Universal Mount Mini Rocker
Gear train: 3-Stage Planetary
Gear Ratio: 136:1
Clutch (freespool): Sliding Pin and Ring Gear
Brake: Roller Disk
Drum diameter/length: 2.25"/4.7" (57mm/119mm)
Kit Shipping Weight: 31.4 lbs (14.2 kgs)
Rope: Synthetic, 7/32" x 50' (5.5mm x 15.2m)
Fairlead: Roller
Recommended Battery*14 amp/hour minimum
Duty Cycle: Intermittent
Battery Leads: 6 gauge
Finish: Steel Grey Powder Coat
Warranty: Limited Lifetime (valid in USA and Canada only)
Winch Weight: 14.4 lbs (6.5kgs)
*Designed for use with 12V DC battery systems only. No other voltage systems recommended.:
PERFORMANCE DATA PULL BY LAYER
Line Pull
Lbs.(Kgs.)
Line Speed
FT./min(M/min.)
Motor
Current
Pull by layer
layer/Lbs(Kgs.)
4000 (1814) 4.6 (1.4) 314 1/4000 (1814)
3000(1360) 7.9 (2.4) 232 2/3320 (1506)
2000 (907) 12.7 (3.9) 157 3/2855 (1295)
1000 (454) 18.6 (5.7) 88 4/2512 (1140)
0 25 (7.6) 21
DUTY CYCLES
Load lbs (kgs) Run Time Distance ft. (m) Cool Time (min)
0 2.5 min 55 (16.8) 12
500 (227) 2.0 min 45 (13.7) 10
1000 (455) 1.5 min 27 (8.2) 10
2000 (907) 45 sec 10 (3.0) 10
3000 (1360) 30 sec 4 (1.2) 10
4000 (1814) 10 sec 1 (0.3) 10
