High Lifter Lift Kit for Polaris Magnum 300/330/400/425 (See Application Notes)
SKU: PLK3/4/425
Price: $79.95
Note: Please ensure that your Magnum meets the questionsin the notes section prior to purchasing this product. If you have questions or are unsure if this product will fit your ATV, please call us at 800.699.0947, Monday through Friday from 8 a.m. to 5 p.m. CST and one of our sales representatives can help you determine if this product will fit your ATV.
Polaris 2” Lift Kit
2” Lift Kit Features:
·         Zinc plated
·         Front and rear lift
Important - Before Purchasing this Product, Please answer these questions:
1.Do you have an independent rear suspension?
     If YES - Don't Purchase This Product. Look at
PLK335/500, PLK500-03, or PLK500-04
     If NO - Question 2
2. Do you have a single shock in the rear, and the eyelet is attached to the bottom of the shock?
     If YES - THIS IS THE RIGHT PRODUCT FOR YOUR ATV!
     If NO - Question 3
3. Do you have a single shock in the rear, and the bottom of the shock is a prong like mount, and the eyelet is attached to the rear differential?
     If YES - Don't purchase this product! Look at
PLK425/500
     If NO - I'm sorry. We don't make a lift kit for your ATV.
