High Lifter Lift Kit for Polaris Expedition 425 (99-02), Magnum 500 (99-03)
SKU: PLK425/500
Price: $84.95
Note: Please ensure that your Magnum meets the questions in the notes section prior to purchasing this product. If you have questions or are unsure if this product will fit your ATV, please call us at 800.699.0947, Monday through Friday from 8 a.m. to 5 p.m. CST and one of our sales representatives can help you determine if this product will fit your ATV.
Polaris 425 Expedition and 500 Magnum 2” Lift Kit
2” Lift Kit Features:
·         Zinc plated
·         Front and rear lift
Polaris Magnum 4x4 500 (99-03)
Important - Before Purchasing this Product, Please answer these questions:
1.Do you have an independent rear suspension?
     If YES - Do not order this product. Look at
PLK335/500.
     If NO - Question 2
2. Do you have a single shock in the rear, and the eyelet is attached to the bottom of the shock?
PLK3/4/425.
     If NO - Question 3
3. Do you have a single shock in the rear, and the bottom of the shock is a prong like mount, and the eyelet is attached to the rear differential?
     If YES - THIS IS THE RIGHT PRODUCT FOR YOUR ATV!
     If NO - I'm sorry. We do not make a lift for your ATV.
