GUN BOOT IV TRANSPORT (BLACK) (REQUIRES MOUNTING BRACKET!)
SKU: GUNBOOT-IVTPrice: $65.00
Protect some of your most expensive hunting investments by getting the best protection possible for your valuable rifles while on the trail! A case within a case, this gun boot has a streamlined profile for easy storage in tight spots and is made of a hard polyethylene outer shell that provides heavy duty protection on the outside while inside the soft case is crafted of Cordura® and exclusive Rhino Hide material for durability with two layers of dense closed cell foam. The case is 52" in length and also features a ballistic nylon handle, Mud Guard zippers that prevent debris from entering the case, Kolpin molded zipper pulls and it will float with guns weighing over 12 lbs. (5.45kg). Anatomically designed to accommodate left and right hand bolt action rifles or shotguns,it also has plenty of room for 50mm scopes or rifles with slings attached and is also airline approved. ATV bracket not included.
