YAMAHA MODULAR DOOR SYSTEM
SKU: RHINO-SK-04012
Price: $899.99
Super light & strong 6061 T6 Aircraft grade aluminum construction! This modular door system offers unrivaled versatility, style, and function. Run them open with no skins for open air driving. Lower mesh panel helps prevent your foot from poking through the door and minimize mud from splashing your feet. Skin the bottoms only and you have more mud and debris protection. Drop in the skinned upper door section for a full door configuration and optimum weather protection. Upper doors have rubber gaskets to help seal the cab and are skinned with the same UV protected materials we use on all our soft tops. Too hot? No problem zip open the window, roll it up, and Velcro it into the convenient flap that neatly covers the rolled window! No annoying windows flapping around. Other great features are two door mechanisms – open and close it from the interior and exterior and a door handle on the inside! The best in the category! Use it with the Seizmik Modular soft top #18033 and the vented windshield #30065, and you are all set with a full cab enclosure. Now get out and ride! Each Door Includes: • 6061 T6 Alum mounting plate – only 2.5lbs! • 6061 T6 Alum tubular lower structure - only 5.5lbs! • Bent steel bar upper structure – only 6lbs! • Interior Door handles • (5) 13/64” holes must be drilled in the roll cage on each side for installation • Does not interfere with the hood opening • Interior/Exterior spring loaded mechanical latch • PVC coated UV protected removable vinyl covers • Zip open windows with covers • Drill (5) 13/64” holes in roll cage per side to install • Does not interfere with hood opening
